Trang 1 của 5 1 2 3 4 5 CuốiCuối
Kết quả 1 tới 10 của 45
    Thành viên mới tuoi tre's Avatar
    Apr 2006
    Mặc định Free Unlock BB5 by Dejan
    Hướng dẫn Unlock BB5 bằng JAF
    Chúc Anh em thành công !
    Unlocking using JAF COM emulator :
    run JAF com emulator
    now select comport using same at the device manager
    click activate comport
    then run software
    you can see this while BB5 logger is running :
    Unlock Procedures :
  2. ( tuoi tre ) đã được 7 thành viên cám ơn vì bài viết hữu ích!
    balqis02 (29-03-2008), giabao141002 (03-02-2008), hongthien (20-11-2007), lttcomputer24 (10-05-2008), quanghn (03-01-2008), thaonhu1973 (01-05-2008), tq_mobile (19-03-2008)
    Apr 2006
    click read phone
    click make log
    if you click SPUnlock, this will show
    solution :
    go to this image and clickBB5 calc
    this must SHOW
  4. ( tuoi tre ) đã được 6 thành viên cám ơn vì bài viết hữu ích!
    balqis02 (29-03-2008), quanghn (03-01-2008), quoccongtg (17-12-2007), trungcr-kh (03-01-2008), vulongmobile (13-03-2008), vvaodoi1980 (28-01-2008)
  5. #3
    Apr 2006
    then go back to bb5 logger and click SPUnlock
    then smile if you see this
    ******* CONECTION ******
    For this program you need Fbus cable like DK5, CA43 or similar conected to ports from COM1 to COM9.
    First unpack zip fiole and strat install.bat
    In file "c:\bb5_unlocker\logs\bb5_unlocker.cfg" with any text editor change your COM port setings!
    ******* USING ********
    Program can be started successfully only if is COM port in file "c:\bb5_unlocker\logs\bb5_unlocker.cfg" adjusted properly.
    READ PHONE:
    Reading info data from phone and making BACKUP file for that phone( Field 308,1).
    IMPORTANT DO NOT delete or modify that file because can save your *** if something goes wrong.
    WR BACKUP:
    With that function can write backup file with Field 308,1 if exist in BACKUP folder.
    MAKE LOG:
    Function for making log file . With that log file BB5_calc.exe calculating codes for unlock.
    Working with BB5 phones with RAP3G v.2.x (6630,6680,6681,6682,n70,n90).
    IMPORTANT phone must be without Sim card.
    SP UNLOCK:
    Making unlock with codes calculated by BB5_calc.exe.
    SP UNLOCK PROCEDURE
    Connect cable to PC and be shure com port is adjusted properly
    Start BB5logunlocker.exe
    Connect phone and switch on without Sim card.
    press button READ PHONE and wait until get the message DONE.
    If is everything correct you will see info from phone on screen.
    Pres button make log and wait until get mesage done.
    Log file is in folder LOGS.
    Start BB5_calc.exe to make for you PSW file in folder PSW
    Press button SP UNLOCK and unlock your phone.
    That is all folks
    according to the statment issued by dejan about versions of rap3g
    "Logger works for BB5 with rap3g v2.11 to v2.20.
    Calculator works for any BB5 phone"
    it should work for......
    Nokia 3110Classic RAPGSM v1.1 PA
    Nokia 3250 RAGGSM v1.1 PA
    Nokia 5200 RAPGSM v1.1 PA
    Nokia 5300 RAPGSM v1.1 PA
    Nokia 6085 RAPGSM v1.1 PA
    Nokia 6110Navigator RAPIDO v1.12 PA
    Nokia 6136 RAPGSM v1.1 PA
    Nokia 6270 RAGGSM v1.1 PA
    Nokia 6300 RAPGSM v1.1 PA
    Nokia 6630 RAP3G v2.10E PA
    Nokia 6680 RAP3G v2.0E PA
    Nokia 6681 RAP3G v2.0E PA
    Nokia 7370 RAPGSM v1.1 PA
    Nokia E50 RAPGSM v1.1 PA
    Nokia E60 RAP3G v2.20E PA
    Nokia E62 RAPGSM v1.1 PA
    Nokia E65 RAP3G v2.20E PA
    Nokia E70 RAP3G v2.20E PA
    Nokia N70 RAP3G v2.20 PA
    Nokia N71 RAP3G v2.20 PA
    Nokia N72 RAP v2.21E PA
    Nokia N73 RAP3GS v2.0E
    Nokia N80 RAP3GS v2.0E PA
    Nokia N90 RAP3G v2.11 PA
    Nokia N91 RAP3G v2.20E PA
    Nokia N93 RAP3GS v2.0E PA
    Nokia N93i CEBBO2P (RAP3GS)
    Nokia N95 RAPIDO v1.11 PA
  6. ( tuoi tre ) đã được 8 thành viên cám ơn vì bài viết hữu ích!
    changngo (04-11-2007), duyte (04-03-2008), nguyentuan (07-03-2008), quanghn (03-01-2008), quoc_gsm (12-03-2012), ThanhTuMobile (29-08-2007), vui 123 (05-09-2007), xtruong74 (02-04-2008)
  7. #4
    Thành viên tích cực BlachThon's Avatar
    Mar 2006
    Xóm Dộc, KT, HN
    Free software thôi còn thì vẫn phải có tt mới ăn đc (JAF)
    anh tutorial bằng MT , Nbox thì cám ơn anh nhiều
    6280 cũng là BB5 sao ko thấy trong list nhỉ ?
    Best Regards
  8. #5
    Thành viên mới gsmcm06's Avatar
    May 2006
    theo e thấy unlock được dòng BB5 là hay lắm rồi.cảm ơn bác tuổi trẻ nhiều nhiều.hihihihi
  9. #6
    Vi phạm nội quy anhbag's Avatar
    May 2007
    Question
    Nhưng mà cái JAF của mình nó không nằm trong danh sách port (JAF port). Vậy thì phải làm sao? Dùng driver nào vậy các bạn ơi?
  10. #7
    Thành viên mới giấc mơ-gsm's Avatar
    May 2007
    Wink 6280 sài cpu ver 3.0 ko mở dc đâu !
    Trích Được post bởi anhbag Xem bài viết
    vào computer manage để xem jaf port bao nhiu rồi activ com port là ok
  11. #8
    Mar 2006
    Xóm Dộc, KT, HN
    Thêm cái video tuto cụ thể cho ai chưa rõ , hix
    Best Regards
  12. ( BlachThon ) đã được 2 thành viên cám ơn vì bài viết hữu ích!
    trungcr-kh (03-01-2008), xtruong74 (02-04-2008)
  13. #9
    Thành viên mới TVGSM's Avatar
    May 2007
    Mặc định BB5 đươc unlock bởi JAF rồi
    BB5 đươc unlock bởi JAF rồi thật vui
  14. ( TVGSM ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  15. #10
    Thành viên chính thức hdthang's Avatar
    Apr 2007
    ae giúp em với làm sao để dowoad được chương trình JAF COM EMULATOR ver 1.3 được vậy,còn BB5 unlocker by logs v1.0b by Dejan Kaljevic (c) 2006 thì dowoad ở đâu ae em,em đang cần gấp.cám ơn ae trước nha.
  1. FREE Dejan SL3 logger file converter, FREE SL3 Code calculation after brute force.
    By hungphongmobile™ in forum MX-KEY (by Alim Hape)
    Bài viết cuối: 22-03-2011, 07:52
  2. ASK>>RPL free by Dejan kaljevic 2009
    By ThienKim GSM™ in forum BB5
    Bài viết cuối: 12-08-2009, 07:56
  3. This is Dejan BB5-2 Unlocker free
    By DAIPHUC in forum BB5
    Trả lời: 15
    Bài viết cuối: 03-11-2008, 19:12
  4. new update Free Unlock BB5 by Dejan 2007
    By suwaree in forum Box for Unlock BB5
    Bài viết cuối: 21-11-2007, 10:43
  5. unlock 6085 bằng free tool của Dejan ?
    By kesatnhan in forum BB5
    Bài viết cuối: 19-10-2007, 08:18
